Rear Brake Binding
Old Mar 5, 2013 | 04:32 AM
spike47's Avatar
Default Rear Brake Binding
Hi
I seem to have a problem with my Off Side Rear Brake ( Discs) on my 2003 Mini Cooper (R50) , it does not seem to free itself after applying the brake , I have removed the Pads and wound the Piston back and refitted everything and the wheel spins OK , then when I check that wheel the next day , it is still binding I have done that a couple of times .
I can not understand what will make it do that , I have disconnected the Hand brake cable , but it is still binding , has anyone any clues as to what could be the problem , there does not seem to be a lot you can do with the Caliper ! .
cheers
spike
Old Mar 5, 2013 | 07:56 PM
It sounds like the caliper is binding and not retracting properly.
I'd say new or rebuilt caliper time.
Old Mar 6, 2013 | 04:35 AM
spike47's Avatar
Hi
Thanks for your reply , I purchased a second hand one Yesterday , but it looks like I will have to get a new cable , because I can not remove the part that goes into the Caliper without damaging it , I have give it a wd40 spray so will check again , but boy is that stuck into the Caliper , I would suggest anyone with a Mini same has mine to put this on there maintenance chart and get it free then put some Copper slip on the Flange , hopefully I can do that but I would think it needs a bit of heat on it ! .
cheers and thanks
spike
lmalbright
Aug 24, 2012 05:38 PM
MINIPartsMass
Jun 12, 2012 10:25 AM
william hardgrove
May 18, 2012 11:12 AM
bmwbob
6
Mar 19, 2012 06:18 AM
ez3022
Jan 6, 2010 11:13 AM
