2002 Mini Cooper S smoke?
Old Dec 6, 2008 | 12:59 PM
tysonb's Avatar
Default 2002 Mini Cooper S smoke?
Im not sure what is wrong with it exactly but when i make sharp turns its starts smoking out of the engine. I have tried putting power steering fluid in it but it still has the same problem... Any suggestions?
Old Dec 7, 2008 | 06:42 AM
yuille36's Avatar
Member
Default RE: 2002 Mini Cooper S smoke?
I would recommend putting your car on a lift or jack stands, and checking the hoses leading from your power steering reservior, to the power steering pump. Somewhere you have a break or leak in the hose, this is causing the fluid to be sprayed on to the exhaust manifold causing smoke.
http://www.realoem.com/bmw/showparts.do?model=RE33&mospid=48021&btnr= 32_1267&hg=32&fg=20
CVVSkipbrady1
Aug 16, 2015 05:36 PM
jeffc
Aug 12, 2014 11:17 AM
headhunter92
Oct 4, 2011 04:35 PM
jamiew
Oct 11, 2007 12:13 AM
mattman8713
Jun 19, 2007 07:26 AM
