2002 R53 Air Bag/ SRS light
Old Mar 7, 2018 | 11:49 AM
newbaycolony's Avatar
Default 2002 R53 Air Bag/ SRS light
My R53 airbag light is on. When I hook up my Creator C310+, I get a "0B Battery, positive terminal isolation 1" fault code, After I clear it, I get "04 Airbag, passenger, stage 1" code. When I clear that one, it returns to the battery code again. I have replaced the battery cable. My original cable was not blown. I tried the resistor trick with 3 different resistors. Still the same. I'm lost. Thanks in advance.
Attached Thumbnails 2002 R53 Air Bag/ SRS light-20180215_155040.jpg   2002 R53 Air Bag/ SRS light-20180215_155114.jpg
Old May 31, 2018 | 10:09 AM
Krick's Avatar
Default Any dice?
Did you ever find out what was going on? I have the EXACT same set of problems, and am reluctant to try to splice in the resistors.
Old May 31, 2018 | 01:34 PM
Thumbs up Yes I Did.
I exhausted all my research, brought it to a MINI independent repair shop and it stumped everyone so off to MINI of Warwick RI and they chased down a faulty connector that runs with the Positive cable. They had to gut the interior to get to it too $767.00 ($9.00 in parts) later, the light is off. I changed cable ends, air bag modules and put in the resistors with no luck. I think if I would have changed the whole cable instead of just the end, I would have found it. Good luck with yours. NBC
Old May 31, 2018 | 02:01 PM
Krick's Avatar
Default Sounds like a fun afternoon...
well...crud.
You wouldn’t happen to know the part number, or any idea of it’s location? $9 sounds like I would rip out the floor to fix it if I can vs the >$1000 I’m looking at otherwise. When you say runs alongside the positive, is it in line? Or splits off?
Old Jun 1, 2018 | 07:31 AM
Default Here is the Description from the Dealer
This is the description I got from the service rep. I did not get to talk to the tech who did the work. Hope it helps.
File Type: pdf
MJohnson121
Jun 27, 2019 09:44 AM
droptopcoop
Aug 1, 2018 04:03 PM
Paul Hogan
Aug 24, 2017 09:29 AM
UPTOWN
Oct 19, 2010 03:11 PM
Jeffrimerman
Jan 7, 2008 08:09 PM
