2003 Cooper s- fuel filter replaced, now no start
Old Jun 3, 2018 | 04:36 PM
Lgrande's Avatar
Default 2003 Cooper s- fuel filter replaced, now no start
I recently replaced my fuel pump.everything worked fine and I decided to change the fuel filter yesterday. I changed the filter and put everything back together and now the car won't start. I filled the gas tank and double checked all the o-rings but still no start. The car turns over but no start. My first thought was fuel pressure but I'm lost at this point
Old Aug 6, 2018 | 01:52 AM
SuPeR-aNi's Avatar
Did you disconnect the battery? If you did it could possibly just be the computer having to relearn itself and trying to find a base idle.
Old May 19, 2020 | 10:54 AM
Ray Lagasse's Avatar
check the fuel line at the fuel filter verify it has a good o ring
Old Jul 1, 2020 | 01:46 PM
Yep you might not have a good seal on the oring.
Old Jun 9, 2021 | 04:10 PM
R56JCW2009's Avatar
Default I had same thing
I forgot to reconnect fuel pump because the wire plug is underneath and so not visible. Check you reconnected yours. You may also have air inside. After new pump installed you should turn ignition only on and off 10 times for the fuel to prime the lines....then start engine. Key in push button key out maybe 6 times. Then start as normal.
Dan Davis
May 19, 2020 10:59 AM
sremenap
Jan 11, 2020 07:48 AM
Wildmanrob
Jan 19, 2018 12:37 AM
Deivyd Salazar
Sep 26, 2016 11:33 PM
motorgirl
Dec 11, 2006 02:00 PM
