2004 R53 Windshield
Old Aug 4, 2016 | 09:35 AM
minj's Avatar
Default 2004 R53 Windshield
We need to get the windshield replaced for our cooper s. The price of the windshield isn't bad ($160), but the guy says the A pillar molding will often crack and need replacement. He states the cost is $150 per side.
I've found them here for a more reasonable price, and perhaps they are more reasonable elsewhere.
So, the question is:
If I were to remove these myself and either one were broken, would the windshield leak, or would I have time to wait for a new one to arrive, then have it ready for the windshield company to replace?
Any other advice as to how best to handle this situation?
Thanks!
Old Aug 6, 2016 | 02:28 PM
BUG ETER's Avatar
No, the windscreen should not leak if the seal is not broken around the edge. The A-pillar plastic is for cosmetic and serves no purpose in keeping water/air out. Also, they are cheaper here https://www.ecstuning.com/Mini-2004-..._Trim/ES78173/
for the same part
Old Aug 6, 2016 | 04:08 PM
minj's Avatar
Thanks very much for the info and the link. The guy at the glass shop made it sound essential. Should I also be concerned about the molding being damaged, as seen
I suppose that has to be replaced at the time of the windshield replacement if it is?
Again, thanks.
Old Aug 7, 2016 | 08:38 AM
BUG ETER's Avatar
Damaged moulding should always be replaced. I live in Virginia and the glazier I use replaces the moulding with OEM pieces at no extra charge
Old Aug 7, 2016 | 01:02 PM
minj's Avatar
I'm concerned about being gouged, since he marked the A-pillar pricing up by over 300%. If I were to allow him to replace both A-Pillars, the windshield replacement would set me back close to $500. Judging by his mark up, I guess molding replacement would add another $300-$400.
This guy was recommended by my time proven and trusted copper mechanic, but I may have to check around.
Thanks for the info. Forewarned is forearmed.
Old Aug 7, 2016 | 02:07 PM
BUG ETER's Avatar
Yeah, that sounds way to high. I had a windscreen replaced with new moulding for $155 out the door. I would check around if I were you.
Old Aug 7, 2016 | 09:49 PM
teamslam1's Avatar
I found my pillars on Ebay. Around 30-40 bucks a piece. Good luck!
Old Sep 30, 2016 | 01:06 PM
  #8
Fast.as.Hail's Avatar
Damn you got your windshield replaced for $155???
Safelite wants 500 bucks to do mine
Old Oct 4, 2016 | 06:28 PM
  #9
BUG ETER's Avatar
I got screwed by Safelite in the past. Never again. Which is why I shopped around when I had to replace another windscreen
Old Oct 9, 2025 | 03:28 PM
  #10
micaeljames's Avatar
Member
If I were to remove these myself and either one were broken, would the windshield leak, or would I have time to wait for a new one to arrive, especially if there’s a concern about the windshield bond failing, then have it ready for the windshield company to replace?
Thanks!
If an A-pillar molding cracks when removed, the windshield won’t immediately leak, so you’d have time to get a replacement before the windshield is installed. Use plastic trim tools to remove the moldings carefully, and consider test-fitting the new ones before the installation.
Emianne
Mar 20, 2009 02:39 PM
thechicgeek
Feb 7, 2009 11:52 PM
Toddicus
Nov 6, 2008 06:28 PM
ron
Jul 22, 2007 01:32 PM
squirtle
Oct 23, 2006 08:00 PM
