2006 Mini R53 - Coolant Leak at Radiator Elbow
Old Feb 6, 2023 | 02:09 PM
tdbeale's Avatar
Angry 2006 Mini R53 - Coolant Leak at Radiator Elbow
On the stock radiators there are two plastic elbows screwed onto the radiator where the in and out coolant hoses are attached. I had a leak on the bottom one and could not get it to seal so I ended up just buying a new radiator and replacing it. Now, after replacing the belt tensioner and apparently not being careful enough while jacking the engine up and down, I have upset the delicate seal on the top elbow. I took it off and there is a rubber o-ring that I didn't notice previously. It was in good shape, no visible cracks or damage to the plastic elbow. I cleaned up the 0-ring and re-installed everything - still leaking. I tried various degrees of tightening with no effect.
Has anyone figured out the magic trick for making these little plastic toy elbows seal?
And another question, has anyone found a replacement radiator that does not use these plastic, screw-on fittings?
Thanks.
Tom
Old Feb 7, 2023 | 08:58 AM
Hello.
Aftermarket ones with Metal end tanks.
https://www.ecstuning.com/Mini-2006-...ling/Radiator/
Or the one sided Canada version radiator buts its only one side.
https://www.ecstuning.com/b-genuine-...r/17117570822/
Old Feb 7, 2023 | 09:58 AM
tdbeale's Avatar
Thanks for the info/response. I tried sealing it with water pump sealant and will see today after it has cured a bit longer if it holds. Either way I will probably order one of the metal radiators from you since you took the time to respond. Those plastic inlet/outlets are going to be a continuing problem that I would like to eliminate. Thanks.
Tom
Old Feb 7, 2023 | 06:48 PM
tdbeale's Avatar
The water pump sealant worked on the radiator leak for a few minutes, then started weeping again. It is drive-able now anyway. Ordered the radiator you recommended just now. Thanks for the recommendation.
Tom
Old Feb 15, 2023 | 04:36 PM
tdbeale's Avatar
Default 2006 Mini R53 - Coolant Leak at Radiator Elbow (Update)
Replaced the radiator with an all-aluminum radiator from ECS Tuning. No more leaks.
Old Feb 16, 2023 | 10:35 AM
Thats great!! Glad to help.
pppoter
Apr 7, 2016 11:19 PM
Omran
Jan 7, 2016 01:15 PM
gibbo
Jun 18, 2014 09:49 PM
HANGMAN
Dec 23, 2013 11:58 AM
Alan
Jul 6, 2011 11:20 AM
