Head replacement
Old Sep 13, 2021 | 08:43 AM
AntonioGG's Avatar
Default Head replacement
My car is a 2005 mini cooper S,130.000 mil, recently I discovered it has a bad spark plug thread in cylinder 1, question is, about how much will be a good used head and labor, any advice will be much appreciate
Old Sep 13, 2021 | 08:11 PM
Nzr56coopers's Avatar
A cheaper by option would be to have a helicoil inserted.or it could also be called a thread insert.this a pre-made thread spring type item that screws into your damaged thread on you head.very easy so long as your present thread is not too far gone.$100 should cover easy.local machine shop would be my first contact.
Old Sep 13, 2021 | 08:19 PM
AntonioGG's Avatar
Thanks, but do you think it will last long?
Old Sep 13, 2021 | 09:30 PM
Used in the aircraft industry and is a well recognized repair,should last a longtime.nothing wrong with them.search YouTube for some more information I guess,fully understand you need to be sure.good repair and cheaper than removing the head.
Old Sep 14, 2021 | 07:02 AM
AntonioGG's Avatar
Thanks a lot, your reassuring comments
Lowlyslows
Oct 6, 2021 11:40 PM
Nacho2to
Oct 6, 2021 11:36 PM
Ryan...
Nov 22, 2017 01:30 PM
cylinder head
Sep 21, 2012 10:53 AM
mlg321
Jul 24, 2011 04:00 PM
