-   -   power steering failure question. (https://minicooperforums.com/forum/2002-2006-mini-cooper-s-r53-12/power-steering-failure-question-3027/)
andieopie Apr 7, 2010 08:02 AM
hi. my power steering pump went out. should i replace the fan while replacing the pump? the pump is leaking, so i know it's bad, don't know about the fan.
it is a "while you're there" kinda thing?" i am paying a mechanic to do the work. he quoted 3 hours. would replacing the fan add much time?
thanks
andie
bad venge Apr 7, 2010 07:59 PM
Most buy the remanufactured pump and I believe they replace the fan as part of the rebuild
dadsalfa Apr 22, 2010 10:35 PM
fan is easy
The power steering fan is held on by two nuts accessable by just reaching under the front end.I did mine with out even jacking it up,just the two nuts and the wiring plug.The labor is minimal and could be done anytime by anyone with the right size wrench so I don't see any reason to it replace as long as it's working.(This applies to first generation cars,don't know if it's different for 2007 and newer)
andieopie Apr 23, 2010 10:29 AM
Power Steering Pump Goodish News
I called MINI for the price of replacing pump and fan, they wanted $1700.00.
I found a brand new pump and fan on ebay for $599.00 (same pump MINI uses!)
and then found a mechanic to put it in for me. He charged me $189.00.
Quite a savings over MINI!!!!
andie
dadsalfa Apr 25, 2010 11:12 AM
Good deal!The pump alone is usually about 600 bucks.Labor was very reasonable too.
