Using coolant
Old May 27, 2008 | 10:03 AM
NEWBFORMINI's Avatar
Default Using coolant
I have been noticeing that I am using coolant. The engine does not overheat, it's just that the cooalnt level goes to the bottom of the reservoir. I fill it up, and it disappears again. Is something wrong? Do I have a radiator cap problem?
Old May 29, 2008 | 12:28 AM
cougsfan's Avatar
Default RE: Using coolant
Yes, something is wrong. No need for panic though. It isn't the end of the world. Take it to a radiator shop and have them check it out. It might be a radiator cap, but it could be a lot of things too. Are there any other symptoms accompanying the problem? Like fluid on the ground (leaky water pump), or a smell coming from the heater (leaky heater core). One thing they do these days is check the coolant for hydrocarbons. If it doesn't contain hydrocarbons that would rule out a blown head gasket or cracked head, which is about as bad of a problem that it could be.
Old Aug 1, 2008 | 09:41 PM
MINIofANNAPOLIS's Avatar
you all are making this out to be a big deal!!!! check the top of the trans. if you see a little puddle of dried coolant then you need to replace the thermostat and housing. coolant will also leak from the waterpump. pull down the splash shield and if oolant pous out you need a waterpump. of just pressure test the system and cover all of your basis.
Old Oct 2, 2008 | 06:38 PM
ymperformance's Avatar
Your thermostat is leaking... look between the head and the airbox and youll see the thermostat housing, if you see green, its leaking.
cher palmer
Apr 21, 2015 11:38 AM
GOOP
Aug 12, 2010 11:05 AM
Vaark
May 10, 2010 02:43 PM
stevied
Jan 12, 2009 06:23 PM
GRANDSPORTAUTO
Nov 10, 2008 12:30 PM
