What else should I do when changing engines?
Old Aug 19, 2017 | 06:11 PM
jjcsnlynn's Avatar
Member
Default What else should I do when changing engines?
I am installing a used (100K miles) engine into my 05 Cooper S Conv.
I am planning on changing the front & rear mains, clutch, water pump and rebuild the starter before reinstalling. Of course I will do oil, air filters and thermostat too. I may even change the trans oil too.
What else should I do? I heard you can change the supercharger oil.
Jon
Old Sep 27, 2017 | 10:41 AM
rudy543us's Avatar
Timing chain, Oil pump
Old Sep 28, 2017 | 10:07 PM
jjcsnlynn's Avatar
Member
The timing chain and oil pump only have 100K life? I figured they were designed to go longer than that.
Old Sep 29, 2017 | 10:28 AM
rudy543us's Avatar
This is true, but consider the amount of work to change them out later.
The engine is out, you should just get it done, remember to change the front and rear main seals.
Mike Ballard
Apr 10, 2017 12:58 PM
Jessejames288
Nov 22, 2016 10:16 PM
murfman713
Nov 17, 2016 09:29 AM
Dec 3, 2014 01:11 PM
Maximusmini
28
Nov 6, 2010 02:47 PM
