-   Audio/Visual Electronics (https://minicooperforums.com/forum/audio-visual-electronics-19/)
-   -   subwoofers (https://minicooperforums.com/forum/audio-visual-electronics-19/subwoofers-1717/)
rkiller69 Jan 27, 2009 06:16 PM
subwoofers
would a sobwoofer look and sound nice in a mini cooper?
aftermarket subwoofer
bad venge Jan 27, 2009 06:30 PM
RE: subwoofers
Yes but unfortunately they take up most of the rear hatch area even for a small 10" sub
rkiller69 Jan 28, 2009 04:30 PM
RE: subwoofers
it would sick right?
plus ill get like and 8in or 6in
i dont put alot of stuff in my hatch i guess it would work
bad venge Jan 28, 2009 05:01 PM
RE: subwoofers
Go with at least a 10 the others are not true woofers and response suffers .... Pioneer makes an ultra thin 10 I've been eyeing
rkiller69 Jan 28, 2009 06:14 PM
RE: subwoofers
can u gimme the website to the subs that you have been eyeing and where could i get them installed???
bad venge Jan 28, 2009 06:49 PM
RE: subwoofers
http://www.pioneerelectronics.com/PU...-SW1001S2%7CS4
type in your zip code for nearest dealer
shorty12 Feb 24, 2009 02:20 AM
subwoofers
aftermarket subwoofers sound pretty good inside of the minis i just recently put a 12" sub in mine if you don't mind giving up the whole trunk space then it's a pretty good way to go.
bad venge Feb 24, 2009 08:17 AM
With the pioneer 10 you can make a shallow box the depth of the trunk and make it flat to the lip , use a subwoofer grill to prevent damage when hauling
ChiliCoop Jan 3, 2010 12:31 AM
Old thread, but for those still searching for a subwoofer solution, this one looks pretty sweet. Would be interested in hearing from anyone who's installed one successfully, especially in the R57.
http://integralaudio.com/mini/mini-c...del-120sa.html
That Pioneer low profile 10" subwoofer may be the way to go though. They have an enclosure meant for under seat install that would likely fit nicely into the boot. Going to measure tomorrow.
http://www.pioneerelectronics.com/PU...10U.Shop?tab=D
bad venge Jan 3, 2010 08:49 AM
those would be a nice start , I thought about making a side mount box to allow the bottom to remain unmolested
