Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Toggle switch
Old Oct 19, 2010 | 10:01 PM
colinf456's Avatar
Default Toggle switch
if i wanted to hook up a toggle switch to manually turn on and off my amp how would i go about doing that? im not very electronically savvy so try to be as simple as possible if you could!
Old Oct 20, 2010 | 07:27 PM
Are you trying to hook to the main power line or the remote line ?
Old Oct 21, 2010 | 11:38 AM
colinf456's Avatar
Main power, i wanna try to make it so no power is going to the amp for sure
Old Oct 21, 2010 | 06:32 PM
Is this a 250 watt total amp or 250 per channel ?
You'll need a switch that can handle 25 amps if it's a 250 total or 50 amps if it's a 2 channel
OR you can just get a circuit breaker and open it every time
No offence it might be easier to either take it to a car audio shop and have it troubleshot or get another amp and see if that fixes it
Technique
Dec 17, 2010 06:39 AM
Erik 719
Feb 11, 2009 09:52 AM
Erik 719
Feb 11, 2009 07:35 AM
donaldb
Jan 17, 2009 09:04 AM
Doug B
Jan 7, 2009 10:13 PM
