Cleaning black lower side sills
As I was waxing my Mini I tried not to get wax on the lower black body molding but failed. How does one clean the white streaks left on by the wax? Next time I will probably cover the molding as I wax the sheet metal. Thanks for your help!
I use 3M adhesive remover ... Others use Isopropyl Alchohol , others use WD-40... If you use WD you'll have to wash it down
http://www.showcardetailing.com/bw/ Try this to keep them like new
Bacl to black and others just cover the wax. I used MR Clean magic eraser .It worked like a charm. Also the roof rails . The magic eraser worked well then a little back to black .
John
John
