Old Oct 10, 2016 | 10:34 AM
  #11
Canton Racing Products For Your MINI R52/R53
This Gen 1 MINI Cooper & Cooper S coolant expansion / power steering tank combo is to fix two problems in one kit. Coolant expansion features a billet radiator style neck which accepts the Canton Racing part #81-030 pressure cap or any 30 psi radiator style cap. While the power steering tank comes with a cap and is the mirror match in quality as the coolant tank. Both mount to the factory location brackets on the firewall.
Never worry again about a separating expansion tank and a leaky power steering tank. Solve two problems with this one kit.
Fits:
R52 MINI Cooper Convertible S / JCW 2005-2008
R53 MINI Cooper S / JCW 2002-2008
Click HERE
How To Series
Installing the ECS Tuning Gen 2 MINI Cooper S/JCW Carbon Fiber Intake is a very short afternoon project that will reward you with performance gains and the beauty of one of our hand-laid laminated carbon fiber intake systems. All required hardware is included with your new intake and it only requires a few simple tools. Thank you for purchasing one of our ECS Tuning Kohlefaser Luft- Technik Intake Systems.
We at ECS have a great tutorial available showing you how to get it done, along with complete service kits and a full line of necessary tools!
Fits:
R56 MINI Cooper S/JCW (2007-2013)
R55 MINI Clubman S/JCW (2008-2014)
R57 MINI Cooper Convertible S/JCW (2009+)
R58 MINI Coupe' S/JCW (2012+)
R59 MINI Roadster S/JCW (2012+)
R60 MINI Countryman S/SX(All4)/JCW (2011+)
R61 MINI Paceman S/SX(All4)/JCW (2013+)
Click HERE
Old Oct 12, 2016 | 11:08 AM
  #12
MSD / VMS Racing Wires MINI R50 R52 R53
Put the spark back in your driving with upgraded coil packs and increased diameter spark plug wires from ECS. Cure the chronic misfire problems that have plagued many factory coil packs, with a great selection of both color option replacements and famous MSD 4 post coil pack.
We have complete sets available or just replace the individual components. This is one of the most popular and quick upgrades under the bonnet of your MINI.
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper Convertible S / JCW (2005-2008)
R53 MINI Cooper S / JCW (2002-2008)
Click HERE
How To Series
Braking systems aren't indestructible, they require proper maintenance and care to keep contaminants and moisture free from the system. A full brake fluid flush is recommended to be performed every 2 years or 30,000 miles, whichever occurs first.
A proper flush removes debris left in the system from failed seals or deposits and ensures that the system is moisture free, to help prevent future rust or clogging issues. These kits include everything you need to perform a proper brake fluid flush on your vehicle.
Fits:
ALL MINIs
Click HERE to learn more!
Old Oct 14, 2016 | 08:30 AM
  #13
R55-R59 MINI Spec D Projector LED DRL Headlights
ECS now offers V2 Spec D LED daytime running lights for your MINI R55/R56/R57/R58/R59, designed to look like the later Gen 3 F56/F55 MINI OEM HID Projector headlights.
These headlights feature high impact plastic lenses with a matte black, black chrome, or chrome LED DRL housings. Sets are available for cars equipped with factory halogen headlights.
Halogen Headlight H11 Projector bulbs and LED lower signal bulbs are included. Brighter H11 options are available below by Ziza.
Upgrade.
Fits:
R56 MINI Cooper /S/JCW (2007-2013)
R55 MINI Clubman /S/JCW (2008-2015)
R57 MINI Cooper Convertible /S/JCW (2009-2015)
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
*Halogen projector for Halogen headlights
Click HERE
Old Oct 18, 2016 | 04:43 PM
  #14
ECS Brake Bleeder DIY
Upgrade.
Fits:
ALL MINIs
Click HERE
MINI Countryman / MINI Paceman Wheel Spacer DIY
Installing the ECS Tuning Wheel Spacers is a very short afternoon project that will reward you with a wider stance and the beauty of our all aluminum anodized black wheel spacers. All required hardware is included with your wheel spacer kit and it only requires a few simple tools.
Upgrade.
Fits:
Click HERE
MINI F56 / F55 Wheel Spacer DIY
Upgrade.
Fits:
F56 MINI Cooper / S / JCW (2014+)
F55 MINI Cooper / S / JCW (2014+)
Click HERE
ECS How To Series - MINI R55-R59 GP2 BBK
The JCW GP2 Sport Brake kit was made for MINI exclusively by Brembo. This upgrade kit is for the front red 6 piston JCW GP2 calipers with GP2 vented rotors in the front and solid rotors in the rear.
All brake pads & parts come in one kit with install hardware, we even have an install PDF linked, making installation convenient and simple. Also included is the needed wheel spacers below to clear the front brake with factory 17"+ wheels.
One critical additional upgrade is JCW GP2 larger master cylinder for excellent brake pedal feel, which is a feature in the kit. Read on to learn more!
Upgrade.
Fits:
R55 MINI Cooper Clubman /S/JCW (2009-2014)
R56 MINI Cooper /S/JCW (2009-2013)
R57 MINI Cooper Convertible /S/JCW (2009+)
-15mm+ spacers will be needed to clear front brakes with 17"+ factory wheels.
Click HERE
Installing the Ziza LEDs is a very short afternoon project that will reward you with brighter interior lighting and the beauty of ambient glow. All required hardware is included with your Ziza kits and it only takes a few simple tools.
Let us be your DIY guide, see our How To pdf under Installation documentation.
Fits:
R50 MINI Cooper (7/2004-2006))
R53 MINI Cooper /S/JCW (7/2004-2006)
Click HERE
Fits:
R56 MINI Cooper /S/JCW (2007-2010)
Click HERE
Fits:
R56 MINI Cooper /S/JCW (2011+)
Click HERE
Fits:
R60 MINI Countryman /S/SX(ALL4)/JCW (2011+)
Click HERE
Old Oct 24, 2016 | 02:12 PM
  #15
R55-R59 MINI Cooper S/JCW N14 Valve Cover Kits
A damaged valve cover can cause oil leaks, vacuum leaks, driveability problems, and a check engine light. Additionally, cracks and warping can result in a significant vacuum leak and result in very poor performance.
The MINI Gen2 R55-R59 N14 engine valve cover is prone to damage over time. For this part, an aftermarket replacement is not an option for which ECS supplies Genuine OEM MINI Valve Cover replacements for your car.
Upgrade.
Fits:
R56 MINI Cooper S (2007-2010) / JCW (2009-2012)
R55 MINI Clubman S (2008-2010) / JCW (2009-2012)
R57 MINI Cooper Convertible S (2009-2010) / JCW (2009-2012)
R58 MINI Coupe' JCW (2012)
R59 MINI Roadster JCW (2012)
Click HERE
Old Oct 27, 2016 | 04:02 PM
  #16
BSH Engine Parts
Modern day emission regulations require the use of a closed PCV / Breather system to recirculate combustion blow-by gasses for cleaner operation and to reduce greenhouse gasses.
Due to inefficient capturing of oil particles within the air charge, a dense amount of oil vapor is allowed to be ingested within the intake tract causing deposits of carbon buildup at the intake ports, back of intake valves and oil deposits within the intake plumbing.
All will eventually lead to poor performance, reduced fuel economy and a decreasing octane rating.
Upgrade.
Fits:
R53 MINI Cooper S/JCW (2002-2006)
Click HERE
Fits: N14 Engines
R56 MINI Cooper S (2007-2010) JCW (2009-2012)
R55 MINI Clubman S (2008-2010) JCW (2009-2012)
R57 MINI Cooper Convertible S (2009-2010) JCW (2009-2012)
Click HERE
Fits: N18 Engines
Click HERE
Old Oct 28, 2016 | 09:25 AM
  #17
Helix Smoked Side Markers
We're happy to announce our new R50-R53 side markers. A perfect add-on for the discriminating motorist who wants to add a dash of style; without changing the MINIs great overall wheel arch styling.
Available in smoked, these kits include amber flashing bulbs with silver coatings so you will still retain form and function.
This is an easy upgrade a clean euro appearance from the orange markers that tend to just stand out.
Get a cleaner look
Fits:
Click HERE
Old Nov 7, 2016 | 02:39 PM
  #18
Revive Your Monster | MINI Gen 1
If you've been putting off required maintenance and performance options on your car you shouldn't wait much longer. A little preventative maintenance can keep your MINI from ending up roadside and performance upgrades contribute to the overall driving experience.
At ECS Tuning we've assembled multiple kits of all the common services to help you avoid troublesome hang-ups and costly repairs. We also carry performance upgrades so you can take the basic repair a step further and completely revive your MINI.
Revive Your Monster
Fitment:
Click HERE
MINI R55-R59 N14 Frankenturbo Upgrade
Revive your engine with a performance turbo. Use this as a bolt-on repair option for a failed turbo, or as a direct-fit performance upgrade.
The FrankenTurbo F21M hybrid turbo gives you the option of running the turbo upgrade on your stock tune or upgrading your tune for a more powerful experience.
Use it alone or as part of a complete performance upgrade.
It's alive!
Revive your monster
Fits:
Click HERE
Old Nov 8, 2016 | 04:07 PM
  #19
Valeo R52 R53 MINI S/ JCW Single Mass Clutch Kit
This single mass flywheel conversion kit replaces the stock dual mass in your 6 speed with a more reliable single mass setup.
Dual mass flywheels allow fluid-feeling clutch engagements and offer a more luxurious feel than single mass flywheels. With these benefits come significant drawbacks. Why convert from a dual-mass flywheel to a single mass?
Dual-mass flywheels are expensive, with the cost of replacement and is often double or triple the cost of converting to a single-mass flywheel.
We also carry the replacement clutch if you have already converted to Valeo.
Grab another gear!
Fits:
R53 MINI Cooper S / JCW (2002-2006)
Click HERE
Old Nov 9, 2016 | 02:00 PM
  #20
MINI Year End Clearance Event
We have selected handfuls of products to feature and reduced their price for this one time sale. Deals like this go quick, so act soon or risk missing out.
Limited time, limited stock, huge savings.
Please check application guide on product page to confirm fitment with your vehicle or select your vehicle to confirm.
Click HERE
