has anyone experienced stiff/hard shifting?
Has anyone out there experienced stiff/hard shifting with your MINI? I have parked my Cooper S on my driveway for the past 60 days on my driveway. Temperatures haven't been very cold. Last week when i took it out for a drive I noticed the gear shift was a little hard to shift-as if it needed oil or lubrication. It was even stiffer by the end of my hour long drive. I was concerned it may be a tranny problem and asked an auto parts employee when buying oil, and he said it's not a tranny problem but just needs gear oil. I have driven stick all my life and have never experienced a stiff shifter. I don't see any puddles of fluid on my driveway as I thought maybe my tranny fuid leaked out. I a had a little front end bender during the winter, but it just seems cosmetic, cracking/damaging the front driver skirt. I don't think the tranny could have been damaged could it???
RE: has anyone experienced stiff/hard shifting?
I am no expert, but I am pretty sure that the manual tranny is a sealed unit. This means that the only way to lose the lube is to have it leak out. I do not think you can burn it.
Ihave not experienced any stiff shifting yet, but it might be due to a clutch issue, rather than a tranny issue. I would take it in to have it checked out, but that is just me.
If it is an automatic tranny, I do not know what to tell you.
Good luck!
Good luck!
Thanks for the reply/feedback froglips. I appreciate it. Hopefully you or anyone else will NOT ever have to experience this! It concerns me though about the posts about the S's tranny problems from 2002-2004 models!
Just to be analy correct here , I beleive that the posts you speak of are actually referring to the clutches wearing out really fast (Within 30k miles or so sometimes), rather than there being a problem with the actual trannies. I am pretty sure the trannies are rock solid, or that is what I hear anyways.
Good luck.
Good luck.
Stiff shifter
yes I am experiencing the same problem with my 2012 Mini with 86,000 miles .
i am concerned because it just came off of extended warranty in February and I want to sell it before it needs more repairs. Also it seems to be going through a lot of oil but it’s definitely not leaking.
