problem with run flat tire or indicator?
Old Apr 8, 2008 | 06:37 PM
lynmcki's Avatar
Default problem with run flat tire or indicator?
Hi! New member here with a question......flat tire indicator is on in my 2003 Mini....checked tires and all okay. Anybody have this problem?
Old Apr 8, 2008 | 08:15 PM
Default RE: problem with run flat tire or indicator?
I believe the 03's use a tire size monitor built into the hub it senses a tire size change , I'm assuming that you checked the tire pressure and not just looked at it ...Check the owners manual for resetting instructions
Old Apr 9, 2008 | 11:21 AM
Nubwagon's Avatar
There is a button under the parking brake that will reset this. Press it in & hold it for a few seconds. Wa-laa! No more indicator light flashing in your face.
Old Apr 11, 2008 | 12:59 PM
lynmcki's Avatar
Thanks to both of you! Quick response and all is fine now.
steve-ooh
Mar 11, 2011 05:54 PM
7mgte
May 10, 2010 08:37 PM
Old Cremona
Sep 26, 2009 08:15 AM
jmf003
Sep 8, 2007 11:13 PM
jeff@redlineperforma
Dec 19, 2006 02:21 PM
