03' Cooper S wont start?
Old 02-22-2009 | 09:07 AM
nightkrawler's Avatar
Default 03' Cooper S wont start?
hey guys, im a bmw tech and i have an 03' cooper s in with a no start condition. we're not a mini dealer and cannot do warranty work so i know very little about these. the car is out of warranty however so it was brought to us. the problem was that fuse #6 had blown. this fuse is for the clutch/brake light switch. since the fuse blew the ews was not getting a signal from the clutch switch letting it know the clutch is depressed so it can crank. i replaced the fuse and the customer took the car. a week or so later it came back with the same issue. the clutch switch and the brake light switch were swapped in from different cars so it shouldnt be related to either. though there dosent seem to be anything else on the fuse 6 circuit. i cant for the life of me get the fuse to blow again or see anything that should be causing it to short. has anyone encountered anything similar to this before? thanks.
Old 02-22-2009 | 10:21 AM
You swapped switches , have you monitored Current ??? how close is it to fuse value ???
Have you tried swapping taillight bulbs and enspect wiring/sockets??? Some mini's get water in the tails and the corrosion can cause weird troubles
convict1
07-27-2021 03:07 AM
chris2005mini
12-20-2011 08:53 PM
bomsmini
09-25-2011 09:43 PM
LarryP
03-15-2009 07:52 PM
stuartj
10-28-2007 06:48 PM
