03 Mini Cooper Shift Problem
Old Sep 28, 2020 | 09:27 PM
03minigirl's Avatar
Question 03 Mini Cooper Shift Problem
I have a manual 2003 Mini Cooper base model that started getting stuck in gear. A little lube on the shift cables helped me get it back into neutral, but now its making a bad noise and then making noises and sometimes stalling when I get off the clutch in neutral (see videos). Some research revealed that the throw out bearings were made out of plastic for this car, so it sounds like I may need to replace mine. Does that sound right, or is there something else that may be causing the problems I am seeing like the shifter cables? Thanks in advance for the help!!!
Shifting:
Clutch noise:
robie
Nov 30, 2021 11:26 AM
Abe Froman
Apr 25, 2020 02:02 PM
giannabezzi
Jul 9, 2015 09:24 AM
Motorpsycho
Feb 11, 2009 01:11 PM
karnow
Jul 10, 2008 01:33 AM
