06 mini trans or clutch clicking while driving
I have a 2006 mini, 5 speed manual. While driving and while deceleration the transmission or clutch makes a clicking noise (sounds like a card in a bicycle wheel). It is only heard while coasting and as soon as i give it a little gas it goes away. I can put it in neutral and coast and the noise is still there, revving the engine doesn't change the noise at all and it get slower or faster depending on the speed. As i slow down the clicking is slow. I have searched quite a bit and can't find anyone else with this problem so thought i'd post here. Any ideas would be great. thanks
1 Attachment(s)
So i ended up pulling the transmission and having a friend take it apart. The pin in the differential was broken and all 8 bolts on the differential were loose. I called mini cooper to get the pin but they don't sell any internal parts and said i would have to buy a whole transmission. I found a guy that parts out mini transmissions and was able to get a pin from him. Got it together for $100 in parts (pin plus output shaft seals) and my time. Here are a couple pics of the the broken pin and the new pin. Hope this post will help someone eventually.
Attachment 1195 http://img.photobucket.com/albums/v5.../IMG954560.jpg |
Glad you got it figured out and glad you found the pin you needed. Looks like you did a great job.
Brave move! I would be too afraid to f up to do that haha. Great job!
Originally Posted by Powershift
(Post 20288)
Originally Posted by bwolfgti
(Post 20298)
Well the trans was already f'd, so figured i might as well try it and save $2k
Any idea how it makes that noise? Is the pin hitting the teeth of any differential gears? |
Also for me the noise goes away if I'm in neutral or clutch on. The noise is only when accelerating or decelerating. 5th great sounds completely different, but that's cuz of the Midland having the 5th gear installed differently than the others, I believe.
Yea that sounds like the same thing. It wouldn't do it in neutral or clutch in. The pin wears in half and wobbles i believe.
