2009 Clubman - Stuck Split Rear Doors
Old Sep 14, 2012 | 09:14 PM
JIDavis's Avatar
Default 2009 Clubman - Stuck Split Rear Doors
For no apparent reason the split doors on my 2009 Clubman recently froze shut; can't open with remote or mechanical handles. Took to Flow Mini in Raleigh NC for a check-up; they quoted an estimate of $650!!! for parts and repairs to free up doors. Anyone had experience with this problem; any suggestions for other solutions; thanks much for any advice. John Davis
Old Sep 18, 2012 | 11:24 AM
PelicanParts.com's Avatar
Did they say what the issue was or just..."It's going to be $650..." ?
Old Sep 19, 2012 | 08:11 AM
JIDavis's Avatar
Default stuck split doors
I was somewhat in a state of shock so didn't take it in very well. They mentioned a number of items; the one I recall is actuators.
Old Sep 19, 2012 | 11:56 AM
Unfortunately, I believe moisture gets into an actuator which can sometimes cause it to fail by creating a resistance between it and it's regulator. Try getting a quote from an indy shop and shop around for the parts.
Old May 4, 2019 | 02:58 PM
ElectraHog's Avatar
Default Stuck split doors
I 2010 mini Cooper clubman is doing the same thing did you ever get yours taken care of I’m trying to figure out a way to open them manually so that I can check inside the door panels let me know if you find out the problem thank you
Giessy
Aug 10, 2018 08:04 AM
Pancho Seferina
Jan 18, 2018 10:24 PM
Tpsfoto
May 21, 2015 11:28 PM
Methos
May 16, 2013 06:27 AM
JIDavis
Sep 14, 2012 09:16 PM
