AC Blows Warm If Not On "LO" Temperature Setting
Hello all. Has anyone ever had the following issue? The Air Conditioner only blows cold if it is set to "LO" temperature setting (it blows cold in auto or manual mode when on "LO"). As soon as a different temperature setting is selected, it doesn't blow cold anymore. Suggestions?
From reading other forums, it sounds like it might be caused by the outside temperature sensor. I am going to try to get around to testing the sensor and maybe swapping it out with one from my parts mini this weekend. Hoping it's not bad wiring too.
Im a new owner of a R56 2013 and also same problem ... were you able to get some help on this issue. My A/C si very cold in the lower setting but when I go up to the next click up (is a manual controller) gets warm. With the A/C not running I can tell there is hot air coming out on the lower temp settings ..
Thanks mc
Thanks mc
Arielavalos
Aug 26, 2017 12:52 PM
