ASC sign keeps lighting, what could be wrng?
Old Jan 30, 2009 | 06:06 AM
jetblackmini_dubai's Avatar
Unhappy ASC sign keeps lighting, what could be wrng?
Hi, Im a new member to this forum. I drive a r50 mini cooper 02'.When i drive for a while, The ASC lights gets turned automatically on and cant be turned off. Wht could be the issue?
Old Jan 31, 2009 | 01:07 AM
rkiller69's Avatar
Default ASC light
from my past experience there is 2 things that might have happened
1) the ASC cable is ripped
2) you could have gone into a pothole, my frineds did that to their BMW 3-series coupe
their traction light went on and off
your best bet is to go to a mini cooper dealer and tell them that ur ASC light wont go away
hopefully the mini u got still has warrenty
Old Jan 31, 2009 | 05:10 AM
Default ..
Thnks ..i guess i better tak my bbaby to the dealer!
Old Feb 17, 2009 | 11:25 AM
Also check that the tires are properly inflated ... A low tire can make it sense wrong
Old Mar 4, 2009 | 10:11 PM
Faria's Avatar
Your ABS harness connector plug (pin contacts) have corrosion wiggle the harness and cycle the ignition if it works --- clean corrosion in pin connector plug/ socket warning do not pry on female side pins, if they widen they won't contact properly male pin contacts.
If it does not work: Your ABS module has internal damage and will need repair/rebuild/and or replaced which needs software and aligning
reynold22
Jun 15, 2012 02:29 PM
SuperchaR53ger
Mar 10, 2009 10:15 PM
skcoop
Apr 14, 2008 04:09 PM
zosim
Jan 1, 2008 07:39 PM
miniholic
Oct 22, 2007 11:53 PM
