boot on convertible
Old Feb 18, 2016 | 07:40 AM
fruitloop555's Avatar
Default boot on convertible
How do you take the plastic lining off, my boot sometime will not shut and i think there is water underneath
Old Feb 18, 2016 | 01:14 PM
PelicanParts.com's Avatar
Is your latch not latching on the hatch? You can pull the license plate surround to see if the wiring is wet. Check this thread HERE as it may be useful to you.
Old Feb 18, 2016 | 01:38 PM
the latch works then unlocks itself few minutes, seconds later. We have had a ton of rain. Yes i think the wiring is wet, thats why i want to remove the black plastic and see if i can get the water out out of there.
Old Feb 18, 2016 | 01:55 PM
Click on the thread I posted above. It's a fix to your issue. You'll want to pull the license plate surround to "moisture proof" the assembly.
For the interior panel:
an R53 you take the torx out I know that there are more that 2 so see if you missed some and then the panel should be held by plastic clips pop them out with a trim/panel tool or a flathead screwdriver, just don't brake them.
Old Feb 18, 2016 | 04:51 PM
Thank you, ill let u know if it works!
Jun 12, 2013 01:04 PM
MINIPartsMass
Jul 27, 2012 11:11 AM
MINIPartsMass
Jul 6, 2012 12:33 PM
jenrn1
Apr 8, 2009 08:34 PM
paleta
Nov 5, 2007 02:30 PM
