Brake Repair Kit
Old 05-28-2013 | 08:28 PM
claydog's Avatar
Default Brake Repair Kit
Ok.. so I go down the the mini dealer to find out how much it would cost to get some new brake pads.
So they tell me $28.22 for the front and $28.22 for the back. So I say, great, give me a set of each.
But then they say... "oh, by the way you need to get the Repair Kit as well."
I ask what that is and they say.. "you need it if your replacing the brake pads."
OK, "How much"
"$150.10 for the front, and $101.14 for the back"
"Why do I need this kit???"
"Cause it goes with the brake pads"
S0..
What exactly is in the "Repair Kit" and why can't I just put new pads on if the the rotors are still in good shape? $30 vs. $300 is a big difference.
Old 06-11-2013 | 02:48 PM
Platinum Sponsor
What model and year MINI do you have? I don't know how the brake pads can be that cheap. I think the repair kit was maybe that amount. Repair kits are usually the pins and sliders and brake pad / slide grease, what is replaced when you do the pads.
Also you should replace the brake pad sensors, because they illuminate a light ion the dash to tell you when the pads need replaced.
Thanks and hope that helps.
07-31-2014 01:58 PM
04-07-2014 01:10 PM
Gregan Dunn
10-18-2012 12:48 PM
jfoderaro
09-11-2011 11:25 PM
salsaking60
12-29-2009 07:36 PM
