cooper s radio turns on and off
Old Jun 8, 2008 | 09:46 AM
philraine's Avatar
Default cooper s radio turns on and off
My wife's Mini Cooper S (oct. 2003)stereo switches on and off randomly (without
touching on/off button) can happen when ignition is on or off: travelling or not. I have
even removed the fuse and it still works!! (and still turns itself on
and off). i have tried disconnecting the battery overnight in the hope that it would reset but it needless to say didn't.
Any suggestions - short of selling the annoying thing.
thanks
Old Jun 18, 2008 | 04:27 AM
drifter28's Avatar
Default RE: cooper s radio turns on and off
I think thats a bad ground. also some times people will not connect a ground at all to the chassis of the radio and rely on the antennae to provide the ground but if its rusty around there or maybe an aftermarket antennae it may not be properly installed. try just running a wire directly from that little nut and bolt on the back to a solid ground. you may want to scratch the surface of the car you are attaching ground.
Old Sep 18, 2010 | 06:30 PM
sboushee's Avatar
Default radio
same problem
did that resolve it from turning on and off
Old May 26, 2011 | 02:43 PM
eme160's Avatar
I have the same problem, how do I get to the bolt at the back of the radio?
Thirdorb
Sep 25, 2013 03:36 PM
sneedspeed
Mar 28, 2012 02:21 PM
bellaloki
Oct 22, 2011 07:33 AM
NewMiniCustomer
Aug 11, 2011 03:10 PM
blacter
Oct 18, 2009 07:34 PM
