Cvt
Old Jun 18, 2009 | 10:57 PM
Croper's Avatar
Default Cvt
http://www.automaticchoice.com/Catalogue/vd_cvt.pdf
Above link, states they are of very known tranny except its more than 10 years old.
Can anyone verify this, that the parts are the same and function.
Many Thanks
Old Jun 19, 2009 | 09:03 PM
I'm not following the question/statement ???
CVT transmission have been around for allot longer then 10 years ...
I had one in 1978... Most snowmobiles use the same type of tranny as well
Old Jun 20, 2009 | 04:24 AM
Croper's Avatar
what i meant is that is cooper using the same CVT as in the rover series.
If thats the case are there any modifications adjustments or it was a direct fit from the rover CVTs.
From the link , it shows that some internal parts, are both models the same.?
ECVT and normal CVTs can they be interchanged ?
Old Jun 20, 2009 | 04:59 PM
ECVT= Electronic Continuously Variable Transmission ... I doubt that it would be a direct swap. The mini is pretty wired into the tranny , as well as the paddle shifters ect . The tranny might fit , but I doubt it'd be an easy swap over to get the mini to run again...
msuspartan2009
Oct 27, 2010 09:07 AM
MiniWheats
May 10, 2010 07:39 PM
Losottos
Mar 27, 2010 02:20 PM
banyan
Oct 30, 2008 12:12 PM
imdakine1
Aug 7, 2008 04:09 PM
