Dead driver's side window
Old Aug 23, 2010 | 11:32 AM
vikmed95's Avatar
Default Dead driver's side window
I drive a '04 cooper S. My driver's side window motor may have died (switch on control panel does not work window and all I hear is a clickin "hum" when I try to operate the window), making my door impossible to close fully since the window does not shift down when it opens.*
*Note: Recall that since there is not frame around the entire window, the windows automatically shift down when the door is opened, and shift back up when the door is closed to create a suction and ensure that no air is being lost through the seal.
Thus, my window does not shift down and the door cannot be closed completely. Does anyone know if the door panel can be opened to expose the wiring and motor for the window? Is this a problem I can fix on my own, or must I take it to the MINI dealership in order to fix?
Thanks for your help and time!
Regards,
Vik
Old Aug 23, 2010 | 07:26 PM
try hitting the door panel right above the speaker ... I've seen that loosen up a stuck motor...
Old Aug 24, 2010 | 12:17 PM
vikmed95's Avatar
Haha to be honest, I was a little skeptical of your advice at first; however, it actually worked! Thanks for your help!
Old Aug 24, 2010 | 04:45 PM
I tried it and it worked as well
Old Sep 13, 2010 | 05:36 PM
flynlow's Avatar
Default That was easy
Thanks for the tip. I had to smack it pretty hard a few times but it did eventually free up the window motor. Saved me a 350 mile round trip to my Mini dealer and the cost of a service call. Thanks again.
dhschultz39
May 16, 2010 07:01 PM
jazznuts699
Apr 19, 2010 01:02 PM
dogdoc
Jan 16, 2009 10:34 PM
xxp0werrangersxx
Nov 11, 2007 05:17 AM
FrighteningFred
Nov 21, 2006 04:58 PM
