Engine starting rough
Old Aug 28, 2017 | 03:24 PM
Kevin Special-k Shaw's Avatar
Default Engine starting rough
So i got my check engine light diagnosed about 2 weeks ago and turns out my ect sensor was not connected properly so the plug it in, the light goes away. I get an inspection done as well. I get the car back and when i do a cold start its very rough, almost like it doesnt want to start, i changed the air filter in hopes that it would correct the problem, no luck. It will run rough for about 1 minute or so then its fine everything sounds as it should and i dont feel anything than i normally would. Any ideas as to what the cause would be?
rakmok
Jul 9, 2015 01:36 PM
headhunter92
Sep 6, 2011 03:09 PM
noodle
Sep 19, 2009 03:57 PM
andrew65
Jan 28, 2009 07:43 AM
1fstmini
May 26, 2005 11:46 PM
