HELP with door lock
Old May 26, 2009 | 11:48 PM
04cooperS's Avatar
Default HELP with door lock
hi my 04 cooper s driver door will not unlock using the key or the switch inside the car. i can use the key to turn the lock but i can only open the car from the outside and not the inside. anyone knows what i need to replace here. any info will be great. thanks in advance
Old May 27, 2009 | 06:33 PM
Sounds like the linkage or the actuator is bound up
Old May 29, 2009 | 06:08 AM
04cooperS's Avatar
i removed the cover on the door and the line from the door handle seems to be intact. if the actuator the small black box next to the silver door handle?
thank you
Old Jun 11, 2009 | 07:53 PM
Igorokk's Avatar
Ok guys Im trying to get the wii 64 to work on my wii but when I try to upload from sd it just get an error. What am I doing wrong? Any help you guys can offer would be great or what yall are using to play the 64 games on your wii.Thanks
Coopermini
Feb 2, 2011 08:46 PM
jnking3
Sep 5, 2010 01:42 PM
Fredvs79
Jan 11, 2010 03:50 PM
esther08
Mar 31, 2009 09:40 PM
Coopermini
Aug 18, 2008 08:40 PM
