Horn Problem
The failure rate of the horn assemblies (there are 2) is immense. They often fill full of water or moisture and then fail. As a previous poster said, check for 12v power and continuity with ground at the horn connector when an assistant presses the horn button.
Sep 29, 2014 03:20 PM
