Looking at a 2004 and it has 3 codes
The people selling it are doing as is.. THey want me to get it inspected.
I ran the codes they are P2096 P1692 P0302 It has 154k miles and they want 3k.. What do you guys think ? I am just curious as I am a newbie to minis. Thanks guys |
P2096 Post CatalystFuel Trim SystemToo Lean, Bank 1 - check out this thread here. Some more information here. Check for leaks in the system. Post #11 here gives you a good list to run down to check your system.
P1692 check out this thread here. P0302 is a misfire on cylinder 2 and can be a number of things. Look here for suggestions. If you run through the list and nothing simple fixes it, you could have a burned exhaust valve. Honestly, I'd move on and find a different MINI if I were you. It seems that some of these issues could be more expensive/complicated than it's worth, but if you're DIY capable you could make it a project. Good luck. |
| All times are GMT -5. The time now is 08:39 AM. |
