MAF and other odd readings
Old Jan 7, 2020 | 08:15 AM
Nic900's Avatar
Cool MAF and other odd readings
Hello all. New to the Forum.
I am battling a pitching idle on a 2007 Base Cooper non S, with stalling. My scanner shows the AFR from the MAF sensor fluctuating between 0.75 & 0.77 g/s on a cold engine not running. Also the Absolute Throttle Position constantly bounces between 19.6% and 20% again , engine is cold and off. This is not the behavior I see on our 2011 Cooper S under the same conditions.
The back story to this car is it was involved in a light front end accident. I purchased it with the damaged "repaired" or thrown together as I like to call it. It was giving a CEL P0015, after 30 - 70 miles of driving, the engine would also, sometimes pitch between 700 and 1200 rpm on idle.
I changed the cam shaft sensors and then the VANOS
solenoids with no luck. After quite a bit of reading I decided to look at the timing chain condition. The top guide looked rough so given I had not idea what level of service this thing had received, the car has done over 100k and I am a glutton for punishment, I decided to change the timing chain and while I was in there I replaced the timing gears. So chain changed now I was getting a P0012, but this time it was coming on within a few minutes of the car running. I rechecked the physical timing, all looked good. I decided to invest in a new code scanner as mine was very basic, so I purchased a Launch CR129.
On first use I could see the advance moving for both, so the new gears and solenoids seemed to be working. I decided to disconnect the cam sensors. When I did this the engine smoothed out, the revs dropped to around 800. I plugged them both back in and the engine remained even. I revved it a few times, as it settled it would pitch a tiny bit but would settle down.
I took it for a drive around the block. It stalled twice but as the drive progressed it smoothed out and I thought I'd reset something and fixed it.I left the car to go cold. I started it back up and it pitched for a minute then settled. I took it for another drive and there was still some hesitation. I did some more reading and new plugs and fuel cleaner was suggested as a fix for the remaining symptoms. I hadn't given it new plugs yet so I did that and added a fuel system cleaner.
Now I'm back to it pitching, I tried to drive it again but it was son bad this time it would stall out and I only just got it home again. I switched thew plugs back - still undriveable
The only codes I am getting now is P0300 & P0301 - 0304 for all the misfires, but no longer get a P0015 or P0012 codes but then again I can't drive it
Lastly we have a 2011 which is running fine so i thought I would compare some readings.
With the 2007 off and cold I get the following odd (to me anyway) readings
So this brings us back to the AFR from the MAF sensor fluctuating between 0.75 & 0.77 g/s on a cold engine not running, the Absolute Throttle Position constantly bounces between 19.6% and 20% again , engine is cold and off. Also the O2 sensor 1 is showing a temperature of 14'C whether the car is running or not. The 2011 does not do these things.
I have check the wiring harnesses and can't see any damage but a wiring issue seems the best fit (to my limited knowledge)
So there, as you see I need some help, I throw down the gauntlet anything anyone has would be a huge help. Thanks in advance
mag1
Aug 31, 2024 10:39 PM
EMPIR3
Jul 22, 2019 10:46 AM
30roadster
Mar 25, 2019 10:03 PM
Partello93
Oct 28, 2015 04:29 PM
pmarketingsales
Mar 21, 2015 10:25 AM
