mystery problem!
Old Oct 31, 2009 | 09:37 AM
grrly.girl's Avatar
Default mystery problem!
Hi Folks!
I am new to this site. I am madly in love with my '03 MINI, but it's been sick for a while and I don't know what to do. After driving for say, 20-30 minutes the car starts to shudder when in drive. I can press on the gas--even pedal to the metal!--but it doesn't want to go. Instead it will creep along at a snail's pace, then kick in and zoom away, only to go back to the snail's pace later.
So my questions for you mechanical wizards and MINI enthusiasts are:
a) What the *bleep* is going on with my beloved car?!?
b) Can a regular mechanic work on my MINI or should I wait until the MINI FLOW place opens up locally in a month?
Please help! I miss driving my car! Any advice you have would be massively appreciated! ThankyouThankyouThankyou!
Old Oct 31, 2009 | 05:49 PM
OK manual or automatic tranny ...
I'm thinking it might be a throttle positioning/computer trouble
Old Nov 2, 2009 | 05:24 AM
grrly.girl's Avatar
That would have been pertinent information to share! It's an automatic tranny (sorry, I know that's blasphemous).
Old Dec 2, 2009 | 05:17 PM
Being an automatic it COULD be a tanny touble as well When yousay it shudders do the RPM's remain constant or do they jump around ???
Old Dec 3, 2009 | 07:01 AM
grrly.girl's Avatar
The RPMs jump around a bit
Old Dec 3, 2009 | 06:58 PM
sounds like an idle/air control trouble or the throttle position I mentioned earlier
Old Dec 26, 2009 | 07:02 PM
gijosh's Avatar
Member
i am having a simlilare prob with mine. or mini cooper s 6 speed. doesnt do it all the time but when i start it up, it will not go past 2k rpms with the pedal to the floor. i shut it off a couple times and its fine for a while.
Old Dec 27, 2009 | 09:43 PM
  #8
that sounds like a TPS or computer trouble ...
Since the throttle is fly by wire versus a standard throttle cable
Old Dec 29, 2009 | 08:12 AM
  #9
grrly.girl's Avatar
My Mini was fixed--apparently there are sensors that attach to the brake pads that monitor traction (? I might not have that quite right). One of mine was dead and the other 3 were very "weak". The mechanic said that if they can't detect traction, it will cut power and was therefore causing my problem. He replaced the sensors. It's been 2 weeks since I got my car back and it's been fine. [girl knocks on wood]
Old Dec 29, 2009 | 08:17 AM
  #10
grrly.girl's Avatar
The mechanic also flushed the radiator, and fixed a few other computer things--the latter might have also fixed the problem.
Whatever--I hope this information helps.
DasNerdherder
Jul 14, 2015 09:36 AM
13Hardtop_S
Mar 3, 2014 10:26 AM
FFRCobra
Jan 10, 2013 01:19 PM
saab92xer
Oct 6, 2009 07:34 PM
froofroobydesign
Aug 17, 2009 09:40 PM
