Need Help 08 Cooper S Shifter Arms problem
Old Jul 7, 2023 | 09:25 AM
Pokeypavnoz's Avatar
Default Need Help 08 Cooper S Shifter Arms problem
My Shifter arms disconnected from each other where they connect on top of the tranmission. I reattached them to each other, but now my car's shifter arm is different. Neutral is where 2, 4, and 6th gear used to be, and now 1, 3, and 5th gear is where neutral used to be. The car can still be put into all seven gears, but it's harder for the car to be put into gears 2, 4, and 6 because its so low on the shifter ****. I attached a video of what the shifter **** looks like now. If I knew what the problem was, I know I could fix it, but I just don't know whats wrong because the shifter arm connectors look exactly how they are supposed to down in the engine. Please help
File Type: mov
Feb 15, 2018 04:18 PM
John OKC
May 23, 2017 02:44 PM
May 15, 2015 05:45 PM
joesmithf1
Nov 28, 2009 08:17 PM
TJ Sense
Aug 9, 2008 10:14 AM
