Oil light on when below 1000 rpm
Old Mar 12, 2007 | 04:14 PM
sonar2's Avatar
Default Oil light on when below 1000 rpm
Hello everybody,
Another new guy here. Ifinally purchased my MINI recently, a 2003 Cooper base model in remarkably good condition (hopefully the pic will upload). I love my car just as much as I thought I would, and everything has been great so far. After I changed the oil last week, the oil pressure light comes on whenever the engine rpm is 1000 or less. This improved after I reseated the oil filter, but it didn't eliminate the problem. I also reset the service miles. Could the problem still be caused by the oil filter? Any help would be appreciated. Thanks.
sonar2
Old Apr 9, 2008 | 07:31 AM
shamrock1's Avatar
Default RE: Oil light on when below 1000 rpm
I have a 2002 two little baby> I took it in for oil chanege. I have the same problem. The shop dosn"t know how to fix it. Can you help?
Old Apr 9, 2008 | 08:28 PM
Did you check oil level ??? sometimes a half quart low will cause it ...
Old Apr 11, 2008 | 09:02 AM
shamrock1's Avatar
Hi everyone in mini land. The oil lite is coming on at 1000rpm. It started after I had oil change. Do you have any more ideas? motorwerks is trying to tell me the machanic probably threw a part of the housing away because he did not know what it was. I am still working with the shop to resolve this problem. I don't dare drive it. Thank you
Old Apr 11, 2008 | 04:14 PM
Any idea what he threw away ??? I'd make them TOW it to the shop , and replace the missing part ... It might be as simple as they didn't seat the oil filter correctly or missing an O ring ect
Old Apr 14, 2008 | 08:19 AM
shamrock1's Avatar
Motorwerks said on the 2002 minis there is somelittle plastic piece that was probably thrown out. I will talk to the shop today again and see what they found out.
Thank you
Modball Team
Jun 21, 2011 08:14 AM
h22boi
Jul 18, 2010 10:57 PM
durst autosports
Jul 28, 2009 02:56 AM
indopassat
Jun 7, 2009 01:09 AM
ronnie948
Sep 13, 2008 12:10 PM
