Oil reset kit
Old Jul 20, 2015 | 02:53 AM
Liliflower's Avatar
Default Oil reset kit
Symptom: "CHANGE ENGINE OIL SOON” warning
how to reset change oil maintenance light
tool
SI BMW oil reset tool 13 bucks
Then plug the SI-reset tool into the OBD2 port of your vehicle (BMW Mini & Rover 75 vehicles after 2001 via OBD2 socket). All LED’s of SI-Reset will blink and stay on.
Next, turn on the ignition switch to enable the board electronic but do not turn on the motor.
After that press the button for the operation you want to perform shortly. The LED light which you already chosen to operate would illuminate, the other LED's would be off vice versa.
If all LED's display a light chain which means oil reset process is completed.
Warm Prompt:
You need to make an inspection reset before an oil reset on some dashboards. Please consult mechanic or engineer before oil reset.
toddjlyons
Mar 8, 2011 08:51 PM
highrpm
Oct 14, 2009 05:57 PM
lawddf
6
Feb 14, 2009 03:41 PM
jon.hill@sbcglobal.net
Feb 6, 2009 09:13 AM
yuille36
Aug 26, 2008 02:14 PM
