power window not working
Old 08-03-2009 | 12:24 PM
bsend's Avatar
Question power window not working
2004 S series sat for 2 months, now the drivers side window will not work. Passenger side works fine. What do I need to look for?
Old 08-03-2009 | 11:22 PM
check for voltage at the motor ... might be a bad motor
Old 04-07-2010 | 03:35 PM
robyn's Avatar
my passenger window will not roll up....how do you check voltage at motor? Thanks for the help
Old 04-07-2010 | 07:51 PM
Gordough's Avatar
I had the same problem with my 04 MC passenger window. It didn't work for about 2 weeks until I found a temporary solution on the web. I was prepared to take the door panel off to repair/replace the window motor. However I learned that the problem is stuck brushes or the like in the motor. The fix to get the window going again is to rap hard just below the speaker with your open hand and voila the window is working again. Its been working fine now for the past 5 months. Saved me a lot of money and effort.
Gord
Old 04-21-2010 | 09:14 PM
MINIWERX's Avatar
The window motor is bad. When they sit that is common for them to lock up. If you want I can replace that window motor for you...
Old 04-21-2010 | 09:21 PM
MINIWERX's Avatar
If you have the door pannel off the door and un-plug the connector on the motor. Then hook up a DVOM (volt meter) to the power and ground, press the switch and the meter will show battery voltage (12v) or close to 12v. If you get 12 than your motor is bad.
Old 04-21-2010 | 09:26 PM
MINIWERX's Avatar
Gord
Hi, that is very much so. I use the same method to diagnose if the fuel pump is bad. If you ever decide to fix that window motor I can help, I have replaced hundreds. Just let me know. Thx
  #8
Old 04-22-2010 | 05:07 AM
robyn's Avatar
Default Power Window Motor
We had to take the door panel off, remove the motor and give it a good smack. Has been working fine since. Found out that the motor got stuck, a good swift pounding and she's back to normal.
  #9
Old 11-02-2010 | 10:04 PM
Grumpy Pirate's Avatar
Default RE: Stuck Passenger Window
Hey gang, a newby here so helllooo! First I must say that after longing for a MCS since 2002, I finally took the leap yesterday and picked up a 2003 with 57k on it. Secondly, today the passenger window quit working but in the up position. This infuriated me as I have so many reservations about owning such a great yet possibly problematic little car to begin with. This led me to you guys and your proposed solutions. I am proud to announce that the pounding above the lower speaker while holding the toggle in the up position did the trick!!! (insert loud applause here) Anywhooo, my humble thanks!!
Peace
08-05-2013 05:08 PM
arahsay
04-19-2012 10:50 PM
Birdman31
06-13-2010 08:40 AM
jazznuts699
04-19-2010 02:02 PM
perkman
09-06-2008 09:34 PM
