problem with lights
Old Dec 22, 2009 | 05:50 PM
jrnardi's Avatar
Question problem with lights
I just bought a 2002 S and I'm having problems with lights. Some of the lights work and some don't. For example:
- the left signal lights all work, none of the right side work (but the signal flasher blinks correctly on both sides)
- the left low beam works, the right doesn't
- the right high beam works, the left doesn't
- the left front parking light works, the right doesn't
- the right rear parking light works, the left doesn't
- the top light on both rear sides doesn't light (what is it for?)
I've swapped bulbs, checked fuses
Any suggestions?
Old Dec 22, 2009 | 07:15 PM
check for voltage at the sockets on the bulbs that are not working
sounds like you have a hell of a mess ... did the car sit for a long time ????
I'm thinking corrosion or rats/mice ate the wiring harness
Old Dec 29, 2009 | 10:43 AM
jrnardi's Avatar
Default lights problem - operator error
Doh! The problem was a 50 amp Fusible Link.
Lois Lane
May 23, 2010 01:06 AM
miniguy01
Nov 11, 2007 04:09 PM
Signman
Oct 22, 2007 08:20 AM
ZJR2020
Sep 6, 2007 10:43 AM
mgg1500
Sep 30, 2006 11:35 PM
