Rough low idle and always needs a second start each morning
Old Dec 22, 2011 | 09:49 PM
LadyV's Avatar
Default Rough low idle and always needs a second start each morning
I have a 2002 Cooper S
My idle sits just under 1000 RPMS, which likes to bogg out and sound like it's going to stall. This has been recent over the last couple weeks following its hesitation to start in the morning: Every morning it turns over a bit slow, then starts, but struggles and dies out almost imediately. Sometimes I can save it by hitting the gas, but the 2nd start-up always works fine. I just started feeding it seafoam and lucus injector cleaning additives to the fuel, but wonder if there is something else going on that someone has any insight on. ?
BTW, I know I go up and down some hills in my area when driving, but does 20MPG sound a bit low? Maybe it's all part of the same problem?
Old Feb 18, 2016 | 01:35 AM
Elmini79's Avatar
Default Did you managed to solve this issue??
Old Feb 18, 2016 | 01:30 PM
PelicanParts.com's Avatar
It turning over slowly seems like it would be a starter issue. Just to rule it out, did you test your battery to make sure it's at a good voltage? I'd plug into your OBDII port and see if any faults are present. Does the car stall out ever?
pmarketingsales
Mar 21, 2015 10:25 AM
ijourneaux
Aug 23, 2011 03:20 PM
GunnyJC
Feb 7, 2010 07:34 AM
browneee
Jun 25, 2007 01:17 PM
1fstmini
May 26, 2005 11:46 PM
