suspension indication flashes
Old May 13, 2012 | 08:12 PM
headhunter92's Avatar
Default suspension indication flashes
when i drive down the road i get an indicator on the tach that comes goes goes. happens pretty regulary. it has something to do with the stability control system. i checked for codes but there nothing there. seems like whenever i hit bumps it pops up. anybody had this issue before ? the indicator is a a yellow circle with a triangle in it and an exclamation point next to it. also theres a red circle with quotes and an exclamation point in the middle and its red. the brake light and a yellow circle a triangle lit up also. anybody got any ideas ?
Old May 13, 2012 | 08:53 PM
i got an idea......how about it needs brake pads ? i just looked in the book and one of the indicators says low brake fluid. low brake fluid is usually an indicator of worn pads.
Old May 14, 2012 | 11:21 AM
PelicanParts.com's Avatar
You can always visually inspect the brake pads first to see how meat is left on them before buying a set.
Old May 14, 2012 | 03:35 PM
The yellow triangle sounds like the Tire Pressure light but different on mine ...
Unsure the year you have
check the owners manual to be sure
Kirsten
Apr 17, 2011 07:14 PM
XCM828
May 1, 2008 12:22 AM
peanuts
Dec 29, 2006 03:35 AM
squirtle
Oct 23, 2006 08:00 PM
mini05
Sep 28, 2006 06:37 PM
