Thanks for the offer mini tech, I need help
Old Feb 8, 2009 | 05:02 PM
kelsey_ali@yahoo.com's Avatar
Default Thanks for the offer mini tech, I need help
Power steering suddenly stopped. I have a 2002 Mini (non S model). Could it be a fuse? Fluid? No sign of leaks or damage. Any other suggestions. I am lost girl without money or an owners manual
Thanks again,
Alison
Old Feb 8, 2009 | 05:29 PM
There is a fuse , unfortunately if the fuse is blown there is likely an electrical trouble that is more serious , the pins on the plugs corrode and can short out .. if it's not that the pump may need a rebuild
Old Feb 9, 2009 | 09:38 AM
ok, so is the fuse located in the fuse box? i do not have a manual, so not sure where or which fuse(s) to check. this did occur shortly after a car wash, so your advise seems on track. thanks so much!!
Alison
Old Feb 9, 2009 | 07:04 PM
F8 30A control power K69923 Relay, electric power steering pump cooling fan/Switch unit Heating & A/C blower
FL4 100A Electric Steering control unit/Hydraulic pump
These are the underhood fuse block...
K69923 Relay EHPS fan power steering / Behind passenger compartment fuse panel
XCM828
May 14, 2024 08:20 AM
FLMINI-Mech
Dec 22, 2023 12:55 PM
MiniWorx
Apr 19, 2012 03:40 PM
MINI JCW 2011
Jul 18, 2011 08:01 AM
MINIofANNAPOLIS
Feb 16, 2009 06:33 PM
