Window close problem
Old Aug 3, 2008 | 10:40 AM
glennrockowitz's Avatar
Default Window close problem
Hi, just purcahsed an '08 Cooper S. I'm assuming I have to take it in to be serviced for this problem, but I was just wondering if any new Mini owners have experienced this:
My passenger side window doesn't zip shut when the door is closed. I have to do it manually now. I'm sure this is a malfunction, but wondering if I can avoid the lost workday required to get my car into the dealership.
Any suggestions?
Thanks!
Old Aug 3, 2008 | 07:10 PM
LAAutoAl's Avatar
Default RE: Window close problem
All The auto up windows need to be initialized when the vehicle goes thru the pre-delivery inspection. If not they do not work properly.
The usual way to initialize them is: have the ignition on, with the door closed roll the window all the way down and holding the button down. After the window reaches the bottom of its travel, hold the button down for 3 seconds more. Then roll the window all the way up holding the button up and hold it in the up position for 3 seconds after it reaches the top of its travel. This is the way it was done on BMW's and should be the same procedure.
Old Aug 3, 2008 | 09:16 PM
Problem solved! Thanks so much for your help!
Old Aug 27, 2017 | 02:28 PM
Clive's Avatar
Many thanks I had to charge the battery on my wife's car and had the problem with the windows not closing when I got out.
The method worked perfectly.
Paradigm
Jun 19, 2015 11:31 AM
Aug 5, 2013 04:08 PM
jazznuts699
Apr 19, 2010 01:02 PM
Yankskid55
Aug 6, 2009 01:00 AM
ashmc84
Nov 13, 2008 11:04 PM
