06 Mini base with CVT no crank no dash gear display
Old Oct 28, 2022 | 08:30 PM
06 cvt survivor's Avatar
Exclamation 06 Mini base with CVT no crank no dash gear display
Help! I have an 06 Mini with CVT initial issue was no crank unless pressure applied to shift lever while starting. It would start and run normally after that. Now it will not crank and the dash display does not display most gear positions only reverse and drive no park or neutral. I have swapped out the shift console assembly as well as the transmission control module and a 5 amp fuse related to park all with no effect.
06 cvt survivor
Oct 28, 2022 08:14 PM
Yellofello
Sep 9, 2020 03:35 PM
Brian Draper
May 18, 2020 03:56 PM
lolo1964
Feb 18, 2015 05:25 AM
mike98789
Jul 11, 2011 03:51 PM
