Ambient lighting
Old Sep 15, 2015 | 01:42 PM
RadDad56's Avatar
Member
Default Ambient lighting
My 2012 has the ambient lighting that you can change the color and brightness of. Does anyone know how to turn it off? Could not find that in the manual.
Old Sep 16, 2015 | 11:36 AM
PelicanParts.com's Avatar
Your manual should go over how to set the lights to a single color. I do not believe you can turn them off unless you somehow code it in the ECU. There is a thread here that should be helpful to you for getting it to stick to one color.
Old Sep 16, 2015 | 12:18 PM
RadDad56's Avatar
Member
it is a very strange feature, I have tried several different colors and usually keep it as low as possible. I started with blue thinking it will not be as harsh, but the red actually makes it seem darker in the cockpit. It doesn't bug me, I just wonder how they did it without causing glare in the windshield.
Old Sep 16, 2015 | 02:31 PM
You may have some luck finding a MINI specialist shop and seeing what they might be able to do in terms of possibly coding them to turn off permanently.
Old Sep 22, 2015 | 08:33 AM
It Cannot be turned off by using the button. Unless you have NCS expert and turn the color function off. It can be dimmed down and use a less harsh color like the orange, yellow, or red mixed color.
Jul 7, 2014 02:34 PM
Dec 18, 2013 09:28 AM
minuteman
Jan 28, 2012 03:00 PM
brunswick
May 22, 2011 08:47 PM
jetblackmini_dubai
Mar 4, 2009 10:11 PM
