Door Lock Problems
Old May 21, 2011 | 05:06 PM
1rickmini's Avatar
Default Door Lock Problems
This is my problem. I have a 2005 Convertible S with only 25,000 miles on it. My drivers side door will not open when I try to open the door from the inside handle. I can only open it by using the unlock feature on the dash and then reaching out the window and opening the door from the outside handle.
The door will lock and unlock from the key remote but again the inside door handle will not release. I went to the dealer and was told I needed to replace the door actuator. My problem seems to be different then most I have read about online. I have also read some interesting comments about disconnecting the battery and resetting the system. However, someone stated this caused additional problems. Not sure why. Anyway, if anyone has any advice please let me know.
Old May 21, 2011 | 11:08 PM
I'm not buying the actuator as this would cause the remote/switch to not work...
Since you state it DOES. I'm betting that there is a linkage trouble
Old May 22, 2011 | 10:21 AM
1rickmini's Avatar
Thanks Bad Venge, I have agree with you. To me it appears that the cable may have come undone. I just need to find a diagram that will show how to run the cable. Don't like it when the dealer tries to sell me something I don't need.
Old May 22, 2011 | 09:15 PM
Old May 30, 2011 | 06:06 PM
orca17's Avatar
Member
The fact that it works with the remote rules out the actuator, IMO. Sounds like a linkage problem, like bad venge said.
jnking3
Sep 5, 2010 01:42 PM
Fredvs79
Jan 11, 2010 03:50 PM
04cooperS
Jun 11, 2009 07:53 PM
esther08
Mar 31, 2009 09:40 PM
Coopermini
Aug 18, 2008 08:40 PM
