Engine needs to be replaced on a Mini Cooper 2010
Hello
I need the engine on my Mini Cooper 2010 replaced as the old one ran out of coolant and ran hot for about 30 mins (Bad I know). The price to replace the engine with another engine with 50K on it including labor is $ 5,700. Does this sound reasonable (The resell of the car itself with a good engine is ~$6,000) Additional questions: What kind of warranty should I expect? Does it need a compression test? Should I also replace the clutch? I am checking on whether the engine been rebuilt and its other history. Thanks Mel |
Hi Mel,
Hope all is well! Just wondering what you did with your Mini. I have exactly the same issue. I also have a 2010 Mini Cooper S (manual) that needs a new engine. It also has around 50k miles :( Thanks, Bob [QUOTE=puregood;26906]Hello I need the engine on my Mini Cooper 2010 replaced as the old one ran out of coolant and ran hot for about 30 mins (Bad I know). The price to replace the engine with another engine with 50K on it including labor is $ 5,700. Does this sound reasonable (The resell of the car itself with a good engine is ~$6,000) Additional questions: What kind of warranty should I expect? Does it need a compression test? Should I also replace the clutch? I am checking on whether the engine been rebuilt and its other history. Thanks Mel[/QUOTE |
Sounds very similar.
I ended up selling it to the mechanic The warranty was only 1 year for a similar quote so although they get replacement engines from a reliable source it is not a long warranty. You should probably get the clutch done at the same time. In the end I weighed up the resell value with the price of the repairs I thought it was not worth it (Most people I talked to agreed). I ended up with a Mazda :) |
