Weird Noise When Turning....
Old Jul 31, 2009 | 01:32 PM
jenjen68's Avatar
Default Weird Noise When Turning....
When I turn my wheel my Mini makes a weird clicking sound, it does this both right and left.
Any thoughts for me to check out are much appreciated
Gotta love Minis, always something!
Old Aug 23, 2009 | 11:23 AM
flamingvictory's Avatar
Have someone check your constant velocity joints. And your muffler bearings.
Old Sep 19, 2009 | 06:55 PM
fuelport's Avatar
It is your constant velocity joint,part of the driveline that transmits power from the transmission to the wheels. You have one to each of your front wheels and sometimes it can be fixed by moving the grease arround inside the rubber boot to get things lubricated again but most cases it is wise to replace the unit. What year is your car and how many miles do you have on it?
Old Sep 20, 2009 | 04:20 PM
jenjen68's Avatar
actually, we're pretty sure it's just random trim rubbing on the steering wheel. the sound appears to be coming from the steering wheel when it is turned past certain points.
now if only i could figure out how to remove the trim from under the wheel so i could lube it, grrr.
hanes manual isn't much help with that.
Keahiloa
Apr 4, 2021 12:31 PM
mooper
Jul 23, 2015 10:53 AM
rtognazz
Aug 18, 2011 09:04 PM
gijosh
Dec 28, 2009 08:45 AM
michellesmini
Apr 4, 2009 09:00 PM
