R53/2 Water Pumps In Stock Now! by Pelican Parts
Old May 15, 2013 | 01:40 PM
PelicanParts.com's Avatar
Default R53/2 Water Pumps In Stock Now! by Pelican Parts
In the case of the MINI Cooper S, the water pump is driven off the end of the supercharger. This setup is a bit different than most cars where the water pump is driven off the engine belts. When a water pump begins to fail, you’ll notice that the car tends to overheat at low engine speed, such as sitting at a stoplight. When you accelerate, the engine temperature will drop. Now, this is not always indicative of a water pump, but a good starting point.
We offer genuine MINI water pumps - you can shop HERE
We also offer a Water Pump Super Kit for both manual & auto transmissions:
-Water Pump and Gasket
-Thermostat
-Thermostat Housing Gasket
-12 oz. Redline Water Wetter Corrosion Treatment
-1 gallon of OEM MINI Coolant (must be mixed with distilled water)
-Expansion Tank or Thermostat Housing Cap
-Upper and Lower Radiator Hoses
Super Kits are listed HERE
Need help to guide you through this project? Check out our step-by-step DIY article:
R53 Water Pump Replacement
Mark/Pelican Parts
Jul 7, 2015 12:56 PM
Aug 8, 2013 06:30 PM
Jul 11, 2013 11:57 AM
May 1, 2013 01:39 PM
Apr 29, 2013 03:29 PM
