Abs problem 09 r56 where is the faq section?
where is the faq area?
What ABS issues are you having?
Take a peek at our Wheel Speed Sensor testing, might be what you're needing: MINI Cooper R56 Wheel Speed Sensor Testing (2007-2011) | Pelican Parts DIY Maintenance Article |
Originally Posted by PelicanParts.com
(Post 23817)
Take a peek at our Wheel Speed Sensor testing, might be what you're needing: MINI Cooper R56 Wheel Speed Sensor Testing (2007-2011) Pelican Parts DIY Maintenance Article |
Make sure the connectors aren't damaged and they aren't loose. That can trigger a light. Use that article to test the sensors. Also, make sure the unit you purchased isn't faulty. If you have done all this and still have an issue go to the article I linked above and leave a comment in the comment box at the bottom. Our MINI Guru may have additional input for you.
