Abs problem 09 r56 where is the faq section?
Old Jun 22, 2017 | 12:37 PM
Cavrone's Avatar
Default Abs problem 09 r56 where is the faq section?
where is the faq area?
Old Jun 26, 2017 | 04:14 PM
PelicanParts.com's Avatar
What ABS issues are you having?
Take a peek at our Wheel Speed Sensor testing, might be what you're needing: MINI Cooper R56 Wheel Speed Sensor Testing (2007-2011) | Pelican Parts DIY Maintenance Article
Old Jun 27, 2017 | 01:48 PM
Cavrone's Avatar
Take a peek at our Wheel Speed Sensor testing, might be what you're needing: MINI Cooper R56 Wheel Speed Sensor Testing (2007-2011) Pelican Parts DIY Maintenance Article
thanks for the reply, yes I had the trifecta lights scanned, left rear sensor was showing 158 mph with the car sitting still, replaced with duaralast auto zone part, lights wouldn't go out so I had it rescanned , still showing 158 wheel speed on LR, that's where I'm at right now.
Old Jun 27, 2017 | 01:54 PM
Make sure the connectors aren't damaged and they aren't loose. That can trigger a light. Use that article to test the sensors. Also, make sure the unit you purchased isn't faulty. If you have done all this and still have an issue go to the article I linked above and leave a comment in the comment box at the bottom. Our MINI Guru may have additional input for you.
May 18, 2017 11:24 AM
nortonm50
Jan 19, 2017 11:37 AM
Mar 15, 2016 05:22 PM
oracleman
Nov 15, 2008 02:18 PM
DGRAY02
Jan 8, 2008 08:24 PM
